Multiple tcp for same tool
Is it possible to make multiple tcp's for the same tool and switch between them inside the same program?
We are running the program directly on the robot from RoboDK
Yes, it's possible.
First, take a look at the first half of this video.
https://youtu.be/cYAeZAp7kRA
There an example toward the 4 minutes marks with multiple TCP.
When you create a program in RoboDK, you can add "Set tool" commands and select the proper TCP to change the active tool for the following movements.
Hope it helps.
Thanks Jeremy,
I will give it a try.
Rick
Works great !!
Thanks !
Rick
3 Guest(s)
