NACHi Post Format Error and Correction Example
Hi all,
I need help modifying the post processor for a NACHi robot. I think I know what is happening.
This is related to other posts such as:
https://robodk.com/forum/Thread-Nachi-Ge...ight=Nachi
The suggestion to make the post processor to use the user coordinate system by
  1. Open the file: C:/RoboDK/Posts/OTC.py
  2. Comment the line self.REF_FRAME = pose (around line 260, just add the # character in front)
will produce the correct numerical values for the Cartesian coordinate in the post, but still with the wrong format.
I attached 3 zip files here for you to review:
1) the RoboDK file following the spray paint program from the tutorial (yes, I am still learning from those).
2) the post from RoboDK after commenting the line #260ish following instruction above to use user coordinate system. The main program 110 will call 111, 112, 113
3) the post I edited manually to get them working
Here is what I did:
1) Using the teach pendent, I added User Coordinate Frame 1 (same location as the work piece frame in RoboDK) to the robot controller, and also added Tool 1 geometry (same definition as in RoboDK).
2) In 110, before calling the subprogram, I inserted the line CHGCOORD 1 to use user coordinate frame 1. I inserted the line CHGCOORD 0 to user the robot base frame before ending the program. (It is probably a good idea insert these two lines in ALL subprogram though. CHGCOORD is fn113. It should be called before the move(s).)
3) Add a "U" to MOVEX lines. (Note: MOVEX M1J doesn't need it because it is joint move.) For example, in 111
before
MOVEX M1X,L,(222.258,199.775,333.893,0.000,-0.000,0.000),S=200.00,H=1,MS
after
MOVEX M1X,L,(222.258,199.775,333.893,0.000,-0.000,0.000)U,S=200.00,H=1,MS
Note the U after ')'
And that's how I get the program to work. I also compiled and ran these on FD on DESK II before i sent to the robot.
So, my question is: how do I modify the post processor to do these steps automatically?
Thanks!
.rdk   NACHi 1.rdk (Size: 1.78 MB / Downloads: 1,106)
.zip   RoboDK output edited.zip (Size: 1.75 KB / Downloads: 1,004)
.zip   RoboDK output.zip (Size: 1.73 KB / Downloads: 1,103)
Thank you for your feedback. This helps us improve our default post processor for Nachi and OTC robots.
Taking a look at your modifications, I attached an updated post processor for OTC and Nachi robots to handle the following:
  1. Use the CHGCOORD with all set reference frame instructions: the id of the reference will be 0 by default if you don't use any numbered frames. However, you can add a number to your reference frame in RoboDK (for example, rename your reference to "workpiece 1" to generate "CHGCOORD 1").
  2. Add a U after the pose if you are using a numbered reference frame.
Let me know if this works better by default or you would like to see other changes.
.py   OTC.py (Size: 21.25 KB / Downloads: 987)
I've tested out the new post processor. So far so good. : )
I promise I will learn Python next. I think I can get more out of RoboDK if I know it. (It is not hard. It is just time. : p)
Thanks!
Hi all,
I have made some changes in the Postprocessor.
Now my question is if every Robot Model has the same type of functionnaming
I've got a MZ12-01 with a CFD-Controller
Changes I made
The Robot-programname normally  was "MZ12-01-01-A.005"
Change to generate a program in Nachi-Software "MZ12-01.005"
Line 115
self.BASE_PROGNAME = robotnamelist[1] + ''     #
#Before                                            ... + '-01-A'
When calling Subprogram(s) the squaret brackets interfere with the Nachi-Software
Should be
CALLP XX instead of CALLP [XX]
Line 173
mainprog += 'CALLP %03i\n' % (self.PROG_ID+i+1)
#Before ...+='CALLP [%03i]\n'
I would like to know if these are general issues at the Nachi PP or just for my robot-model
Programming isn't my strenght... maybe there are some better solutions
Another thing I would like to change is the numeration of the called subprograms
The Programs start with .005 (always main)
Think it refers to Line 58
PROG_ID=5
My idea would be like this example:
'generate robot program as...'
MZ12-01.XX     #For XX type a number (Main Prog)
                      # Calling X+n subprograms
MZ12-01.XX+1
MZ12-01.XX+2
MZ12-01.XX+...
hope my idea is good, what I fall down on is implementing it...
Markus
