NC data loading error
#11
also seems like G43 has a variable not defined
#12
What do you mean? RoboDK does not support the G43 command.
#13
(09-08-2024, 06:06 PM)Albert Wrote: What do you mean? RoboDK does not support the G43 command.
within the nc program
G43Z62.H#530
Variable #530 is not referenced within the program. I never tried to feed G43 into robodk so I did not know it was not supported, but the variable is still not defined.
Not so much for you Albert, but for the OP.
#14
I understand this issue appears when posting a machining program from TopSolid. We can't help much in this case. It is better if you contact someone from TopSolid.
