Need Movej instead of MoveabsJ
Lightbulb
hi, for this example I take the robodk example of polygon.
you can see the scripts in robodk example with name movepolygon.
in here "robot.MoveJ(target_pose)" is used to create a point in which robot will follow.
but when I generate the robot code,
MoveAbsJ [[0.000000,0.000000,0.000000,0.000000,0.000000,-0.000000],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]],v500,z1,t \WObj:=w;
now my question is, how can I bring MoveJ instead of moveabsJ ??
changing from ctrl+find and replacing absJ to J does not work.
is there any way to bring moveJ not moveabsJ??
Yes, this is possible. I attached a post processor to do so. Let us know if you have any issues. You can replace it for the default post processor.
You'll find a variable called MOVEJ_AS_MOVEABSJ that allows you to configure this behavior.
.py   ABB_RAPID_IRC5.py (Size: 46.56 KB / Downloads: 867)
