View unread Posts
View New Posts
View Today's Posts
Forum Search
Login
Register
Login at RoboDK
Welcome to RoboDK Forum
Not a member yet?
Join Us Now!
Remember me
Lost password
Search
Login
Register
Login at RoboDK
Not a member yet?
Join Us Now!
Remember me
Lost password
Forum
Portal
Members
Today's Posts
Calendar
Help
RoboDK
Forum
Need help, Testing UR - DXF to URscript
RoboDK
Forum
0 Vote(s) - 0 Average
1
2
3
4
5
Laurits11
Junior Member
Threads: 1
10-08-2018, 05:57 AM
I am testing program "UR - DXF to URscript" and I can't figure out how to set the cutting/welding speed anybody knows ?
Quick Edit
Full Edit
Moderator
227
10-08-2018, 12:35 PM
You should select the option "Edit Path Manually" in your cutting project, in RoboDK. This will open DXF2Gcode with your drawing.
Then, you can select:
Options-Configuration
Machine Config
You'll find the feed rates towards the bottom
Quick Edit
Full Edit
Laurits11
Junior Member
Threads: 1
10-08-2018, 03:17 PM
I have tried that, but it still don't work, is it because i am using the trial version ?
Quick Edit
Full Edit
Laurits11
Junior Member
Threads: 1
10-09-2018, 05:54 AM
If i reload the file it is working :-) , thank you
Quick Edit
Full Edit
View a Printable Version
Subscribe to this thread
Copyright © 2026
RoboDK Global
Powered by MyBB
Linear Mode
Threaded Mode
