02-20-2021, 08:57 PM
How can you reset "home" for a robot as a starting point which is different from the default.
New home for a robot |
02-20-2021, 09:29 PM
You can edit parameters of the robot, or just create a target called home and use that, depending on your requirements
02-22-2021, 02:33 PM
Hi Deo,
As Colin mentioned, you can double-click the robot to open the robot panel. You can then select "Parameters" and "Set Home". Creating a Home target is also an option. Jeremy
Users browsing this thread: |
1 Guest(s) |
