No public property 'TIMEOUT' for class 'Robolink error with MoveL()
Exclamation
Hello, I have a Matlab script controlling RoboDK station (attached). I want to use robot.MoveL() function to move to target called '44'. But I am getting an error "No public property 'TIMEOUT' for class 'Robolink'."
Here is my code:
%RoboDK inititalization
RDK = Robolink;
path = RDK.getParam('PATH_LIBRARY');
fprintf('Available items in the station:\n');
%disp(RDK.ItemList());
robot = RDK.Item('UR5e');
tool = RDK.Item('RobotiQ 2F85');
fprintf('Robot selected:\t%s\n', robot.Name());
robot.setVisible(1);
frameref = robot.Parent();
fprintf('Robot reference selected:\t%s\n', frameref.Name());
object = RDK.Item('base');
fprintf('Object selected:\t%s\n', object.Name());
targetMap = [3,3];
valueRow = targetMap(1);
valueColumn = targetMap(2);
home = RDK.Item('44');
robot.MoveL(home);
while robot.Busy()
   pause(100);
   fprintf('Waiting for the robot to finish...\n');
end
Here is my Command window log with error mesages:
>> analysis_test
Robot selected: UR5e
Robot reference selected: UR5e Base
Object selected: UR5e Base
Error in RobolinkItem/WaitMove (line 706)
           set(this.link.COM,'Timeout', this.link.TIMEOUT);
Error in Robolink/moveX (line 272)
           itemrobot.WaitMove();% checks connection
Error in RobolinkItem/MoveL (line 578)
               this.link.moveX(target,this,2,blocking);
Error in analysis_test (line 20)
robot.MoveL(home);
.rdk   robot_station7x7.rdk (Size: 3.51 MB / Downloads: 893)
Can you make sure you are running the latest version of Robolink and RobolinkItem?
You should find the latest version here:
https://github.com/RoboDK/RoboDK-API/tree/master/Matlab
Also, make sure you don't have previous versions of these files in the path.
If you still have issues: What version of Matlab are you using?
Exclamation
(05-25-2020, 09:41 PM)Albert Wrote: Can you make sure you are running the latest version of Robolink and RobolinkItem?
Hello
My MATLAB version is R2021a. I have the latest version of Robolink and RobolinkItem. Unfortunately, I have the same problem. I'll appreciate your help.
Can you provide us with the RoboDK project and Matlab code you used to reproduce this issue?
