Online Program Multithreading
Reposting as I realize this should be in the API section.
I have 2 meca 500s that I am attempting to run movements on at the same time. To do this I have written a synced multithreading function with movements being called to each robot on each thread. When I run in online mode the robots only move one at a time.
Is it possible to have synced movements with multithreading and online programming or do I need to do post processing?
I have attached my code below. Robot.SafeJM is a custom function uses MoveJ_test to check a joint move is safe before running.
class MyThreads:
   def __init__(self,threads):
       self.state=[0]*threads
       self.threads=[]
   def RScan(self,Robot,Rlist,t):
       i=0
       while i< len(Rlist):
           time.sleep(0.001)
           if self.state[t]==0:
               Robot.SafeJM(Robot.LEDT,Rlist[i])
               self.state[t]=1
               i+=1
               if self.state==[1]*len(self.state):
                   self.state=[0]*len(self.state)
           # elif self.state[t]==1:
           #     print('Race Prevented')
   def GScan(self,ESP,Rlist,t):
       i=0
           time.sleep(0.001)
               ESP.patch("goalposLED",Rlist[i])
               ESP.get("zCurrent")
               self.state[t]=1
               i+=1
               #print(self.state)
   def SyncThreads(self,fun,args):
       for t in range(0,len(args)):
           thread = threading.Thread(target=fun[t],args=args[t])
           thread.daemon = True
           thread.start()
           self.threads.append(thread)
       print('Threads started')
       for t in self.threads:
           t.join()
       print("Done!")
Do you use a different Robolink instance for each thread?
To be able to properly use the API on different threads you should use a new Robolink instance for each thread.
A quick workaround is to call this once inside your thread:
robot.link = Robolink()
Or I recommend you to do this properly when you start your thread and retrieve objects using the same link so the correct RDK links are automatically assigned:
RDK_t1 = Robolink()
robot = RDK_t1.Item("robot", ITEM_TYPE_ROBOT)
