  • 2 Vote(s) - 3 Average
PLC MODBUS COMUNICATION
Is it possible read and write variables throuth RoboDK at an external Master Modbus/TCP IP PLC?
Thank you.
Regards
If you want to change variables in a PLC from RoboDK I recommend you to integrate it using Python and a Modbus library. For example:
https://pypi.org/project/minimalmodbus/
If you want to change variables in a PLC from your robot you should customize the output with a post processor:
https://robodk.com/doc/en/Post-Processors.html
(04-01-2020, 09:43 AM)Andros85 Wrote: Hello,
Thank you.
Regards
Hello
im am currently working on a project which requires Robodk to acquire robot waypoints through a PLC,
is there any other methods/modules to setup a TCP/IP communication with a PLC in RoboDK
