Point projection goes through object
Good morning,
I've been working with point projection. When I use the ProjectPoints python script, the script generates a path that goes through the object and projects on the other side. (see pictures attached). Is this a setting, or a problem with the object that I use?
Kind regards.
Can you attach your .rdk file?
Hello, herewith the .rdk file.
Thank you and best regards.
.rdk   MotomanCompletedStation_projectieZonderCircel_MultipleScripts_06.rdk (Size: 4.46 MB / Downloads: 869)
