Problem importing libraries on RoboDK
Hi there,
I have the Python code below and it works perfectly if i run it without roboDK. If i import it to roboDK and run it from there, it returns me an error (attached image) because of the libraries which are not of roboDK. Do you know how can i solve this?
import cv2                                # state of the art computer vision algorithms library
import numpy as np                        # fundamental package for scientific computing
import imageio
import matplotlib.pyplot as plt           # 2D plotting library producing publication quality figures
import pyrealsense2 as rs
import win32gui
import win32api
import time
import pyautogui
from robolink import *    # API to communicate with RoboDK
from robodk import *      # basic matrix operations
# Any interaction with RoboDK must be done through
RL = Robolink()
points = rs.points()
pipe = rs.pipeline()
config = rs.config()
profile = pipe.start(config)
colorizer = rs.colorizer()
align = rs.align(rs.stream.color)
state_left = win32api.GetKeyState(0x01)  # Left button up = 0 or 1. Button down = -127 or -128
device = profile.get_device() # type: rs.device
depth_sensor = device.first_depth_sensor() # type: rs.depth_sensor
if depth_sensor.supports(rs.option.depth_units):
  depth_sensor.set_option(rs.option.depth_units,0.0001)
robot = RL.Item('UR5e')
frame = RL.Item('Reference Frame')
Target = RL.AddTarget('Target 2', frame)
try:
    while True:
       frames = pipe.wait_for_frames()
       frames = align.process(frames)
       depth_frame = frames.get_depth_frame()
       color_frame = frames.get_color_frame()
       if not depth_frame: continue
       #print(width,height)
       depth = np.asanyarray(colorizer.colorize(depth_frame).get_data())
       color = np.asanyarray(color_frame.get_data())
       images = np.hstack((color, depth))
          #cv2.namedWindow('RGB_View', cv2.WINDOW_NORMAL)
       #cv2.setWindowProperty('RGB_View', cv2.WND_PROP_FULLSCREEN, cv2.WINDOW_FULLSCREEN)
       cv2.imshow('RGB_View', color)
       depth_intrin = depth_frame.profile.as_video_stream_profile().intrinsics
       #flags, hcursor, (x,y) = win32gui.GetCursorInfo()
       x, y = win32api.GetCursorPos()
       #print(x, y)
       pixel_coord = [x, y]
       keypressed = win32api.GetKeyState(0x01)
       key = cv2.waitKey(1)
       # Press esc or 'q' to close the image window
       if key & 0xFF == ord('q') or key == 27:
           cv2.destroyAllWindows()
           break
       #Calculate distance
       if keypressed!=state_left:
        state_left = keypressed
        print(keypressed)
        if keypressed < 0:
         if (0<x<632 and 32<y<512):
          dist_to_center = depth_frame.get_distance(x,y)
          dist_to_center = round(dist_to_center, 4)
          depth_point = rs.rs2_deproject_pixel_to_point(depth_intrin, pixel_coord, dist_to_center)
          depth_point = [i * 100 for i in depth_point]
          depth_point = [round(i, 3) for i in depth_point]
          #depth_point = ( ", ".join( repr(e) for e in depth_point))
          with open('Coordinates.txt', 'w') as f:
            f.write("%s\n" % depth_point)
          f.close()
          print(depth_point)
          #print(depth_point[0:5], depth_point[7:12], depth_point[15:19])
          print('The camera is facing an object:',dist_to_center,'meters away')
          Target.setPose(Offset(eye(), depth_point[0], depth_point[1], depth_point[2], 0, 0, 0))
          robot.MoveL(Target)
          time.sleep(0.7)
finally:
    pipe.stop()
Hi there,
There is no image attached.
That's true, here it is,
Sorry.
You should install the Python libraries needed by your application on the Python version you use for RoboDK. This is probably in C:/RoboDK/Python37 (you can find this out in Tools-Options-Other).
Alternatively, you could have a quick workaround by adding this in your code:
# make sure opencv for python is available
import_install("cv2", "opencv-python")
# Load OpenCV
import cv2
