Problems running RoboDK on Windows 8
The software setup is downloaded from the website and is installed on the computer.
After that whenever I try to start the software, it starts and immediately I get an error that RobotDK has stopped working(image attached).
and this error appears twice in a row.
on clicking on 'more details' option I get the following message.
Problem signature:
  Problem Event Name: BEX64
  Application Name: RoboDK.exe
  Application Version: 3.6.1.8537
  Application Timestamp: 5c870d20
  Fault Module Name: StackHash_c6d7
  Fault Module Version: 0.0.0.0
  Fault Module Timestamp: 00000000
  Exception Offset: PCH_EA_FROM_ntdll+0x000000000000315B
  Exception Code: c0000005
  Exception Data: 0000000000000008
  OS Version: 6.2.9200.2.0.0.256.48
  Locale ID: 1033
  Additional Information 1: c6d7
  Additional Information 2: c6d7177f18e00ff82ab902718d1239fd
  Additional Information 3: 0e30
  Additional Information 4: 0e3044ba6250654f69a4886379651f7e
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=190175
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
I would really appreciate your help in solving this issue.
First, I recommend you to check if it is an issue with the graphics card:
  • Double click the file:
    C:/RoboDK/RoboDK-Safe-Start.bat
If it works, it means your graphic card drivers are outdated. I would recommend you to update the drivers.
If it doesn't work, I recommend you to follow these steps:
  • Start RoboDK by double clicking the file:
    C:/RoboDK/RoboDK-Debug.bat
  • Try to reproduce the problem until it crashes.
  • Right after the crash, send us the following file:
(03-14-2019, 12:54 PM)Albert Wrote: First, I recommend you to check if it is an issue with the graphics card:
Thank you so much for your reply. The software is not starting with 'C:/RoboDK/RoboDK-Safe-Start.bat' file. Also while starting the 'C:/RoboDK/RoboDK-Debug.bat' I am getting the same error. It shuts down with a RoboDK has stopped working message. I am attaching the RoboDK.debug.txt file with this message.
thanks
.txt   RoboDK.debug.txt (Size: 2.53 KB / Downloads: 1,490)
It looks like a problem with the graphic card or OpenGL compatibility.
Do you have a dedicated graphics card?
Are you running RoboDK on a virtual machine?
You mentioned this didn't work:
What issues do you have?
While starting with C:/RoboDK/RoboDK-Safe-Start.bat, the software started and immediately I got the 'Robodk has stopped working' error. The same one I get while starting the software normally.
I think it's the problem with OpenGL compatibility.
Thank you so much. I have similar problem. Acording messags my problem related to my laptop Graphic card driver. How can I troubleshoot this problem?
Best Regards
Can you provide more information about your computer specifications? You need OpenGL 3.0 or later including support for shaders to properly run RoboDK.
If you are using RoboDK on an older computer you can try running RoboDK by manually double clicking the file:
C:/RoboDK/bin/RoboDK-GL2.exe
Hi Albert and other guys! Because in your conversation you asking, i have download robodk 4.0 (32-bit) in 32-bit Windows 7 Virtual Machine and it doesn't work. Even i open the files you write, i have the same problem. What can i do;
You may experience issues running through a virtual machine if you don't have proper support for OpenGL.
You can try running RoboDK by double clicking this file:
I got this problem recently, and my problem was my docking station.
I just had to unplug it, start RoboDK and replug it.
