Problems connecting URSIM to RoboDK
I want to connect URSIM to ROBODK, but so far I have been unsuccessful. I believe the problem is the IP addresses and ports I am using. In my virtualmachine the IP is 10.0.2.15. To connect i tried using port 29999, 30000, 30002, 30004.
Any tips?
10.0.2.15 is a NAT ip address and won't be visible to your host operating system. You can verify this by trying to ping that address from your host operating system. What you need to do is change the network configuration of the VM to bridged so that it's on the same network as your host operating system.
(07-16-2020, 12:57 AM)Phillip Wrote: 10.0.2.15 is a NAT ip address and won't be visible to your host operating system. You can verify this by trying to ping that address from your host operating system. What you need to do is change the network configuration of the VM to bridged so that it's on the same network as your host operating system.
thank you for your response Phillip, i figured out how change it back and it did the trick.
