06-03-2019, 11:02 AM
Hey! So I want to run a robot machining project with a g-code file. The difference is that each movement instruction in the G-code like has 3 additional values apart from the normal X ,Y , Z and E parameters as shown below.
These nX, nY and nZ represent the euclidian angles of the robot's tool orientation. When I try running the g-code normally by starting a machining project, although there are no errors, the robot simply goes to a point for the entire operation. Is there a way to input these nX, nY and nZ values from each line of the g-code to the tool orientation angles in the post processor? I am using an ABB IRB120 for the same. Kindly do let me know! Thanks in advance!
G1 X3.650 Y-9.611 Z1.500 nX0.000 nY-0.000 nZ1.000 E0.103
G1 X2.700 Y-9.920 Z1.500 nX0.000 nY-0.000 nZ1.000 E0.169
G1 X1.724 Y-10.139 Z1.500 nX0.000 nY-0.000 nZ1.000 E0.236These nX, nY and nZ represent the euclidian angles of the robot's tool orientation. When I try running the g-code normally by starting a machining project, although there are no errors, the robot simply goes to a point for the entire operation. Is there a way to input these nX, nY and nZ values from each line of the g-code to the tool orientation angles in the post processor? I am using an ABB IRB120 for the same. Kindly do let me know! Thanks in advance!
