Program Generation for Trial version of RoboDK
I am a student and currently have the trial version of RoboDK. I am unable to use the " program generation " feature as it is unticked and gray from the installation stage itself.
Whereas in the subscription plans for RoboDK, it is mentioned :
Trial Version Included features:
  • All Simulation and Offline Programming features available for 30 days
  • Program generation limited to 50 lines of code
  • Unlimited access to the robot library
Can someone please guide me as to what can be done?
Screenshots here
You should be able to generate programs that are 50 lines of code or less with the free version.
Can you attach the screenshots and/or the RoboDK project?
(09-28-2022, 11:15 AM)Albert Wrote: You should be able to generate programs that are 50 lines of code or less with the free version.
Absolutely.
As for the program, for trial, L-shape is being traced by a FANUC R2000iA :
L Trial
import sys
import os
sys.path.append(os.path.abspath(r"""D:/RoboDK/Posts/""")) # temporarily add path to POSTS folder
from Fanuc_RJ3 import *
try:
 from robodk.robomath import PosePP as p
except:
 from robodk import PosePP as p
print('Total instructions: 3')
r = RobotPost(r"""Fanuc_RJ3""",r"""Fanuc R-2000iA/165F""",6, axes_type=['R','R','R','R','R','R'], ip_com=r"""127.0.0.1""", api_port=20500, prog_ptr=1198950288384, robot_ptr=1198953539216)
r.ProgStart(r"""Prog1""")
r.RunMessage(r"""Program generated by RoboDK v5.5.0 for Fanuc R-2000iA/165F on 28/09/2022 14:19:12""",True)
r.RunMessage(r"""Using nominal kinematics.""",True)
r.setFrame(p(0,0,0,0,0,0),-1,r"""Fanuc R-2000iA/165F Base""")
r.MoveJ(p(1807,0,1300,-180,-90,0),[0,0,0,0,0,0],[0,0,0])
r.MoveJ(p(1807,-663.885,1300,-180,-90,0),[-22.6368,7.18155,0.377719,90.9057,22.6398,-90.9813],[0,0,1])
r.MoveJ(p(1807,-663.885,554.289,-180,-90,0),[-22.6368,11.4299,-32.5674,37.7649,38.9372,-31.0727],[0,0,1])
r.ProgFinish(r"""Prog1""")
r.ProgSave(r"""C:/Users/Admin/Desktop""",r"""Prog1""",False,False)
r.ProgSendRobot("127.0.0.1", "md:/", "anonymous", "")
The output I get when I try to run the program directly on the robot via "Ctrl + F6"  :
