Can I program popular microcontrollers like, Arduino boards, raspberry pi pico, ESP32 ... etc, with RoboDK?
Which version of RoboDK should should I install?
Programming popular microcontrollers with RoboDK |
03-23-2025, 05:33 PM
We only have one version of RoboDK which you can download here:
https://robodk.com/download I recommend you to customize one of our G-code post processors for a custom controller made using Arduino, Raspberry Pi or ESP32. You can find more information about post processors here: https://robodk.com/doc/en/Post-Processors.html
OK, after checking other threads and tutorials, it turned out that there must be a computer system running RoboDK and send the control data to the Arduino microcontroller.
The Arduino in this case acts like a driver controller to the servo motor, where I can use any other servo/stepper driver unprogrammed chip. So the least system that can run RoboDK is a Raspberry Pi that can be connected to a monitor and not any less system like the raspberry pico or similar microcontrollers. OK, I get it now. Thanks for the help,
03-25-2025, 09:40 AM
You should be able to control your robot or Arduino from your computer as well. Make sure you have a serial connection like RS232 or equivalent.
| 1 Guest(s) |
