Python API - unexpected behavior of MoveL_Test
I'm using the 'MoveL_Test' method in the following way:
res= MoveL_Test(new_robot_joints,target.Pose())
when res = 0 (which is good, and means I would like to move the arm linearly), I see in the simulation that the arm position changes slightly after the MoveL_Test command (before I'm actually moving it (via 'MoveL')).
Is it a bug, or am I doing something wrong?
(if it helps, here is an example for the pos change:
from Pose(590.000, 0.000, 400.000,  180.000, -0.000, -90.000)
to Pose(442.954, 67.952, 400.000,  180.000, -0.000, -67.569))
Thanks!
Yotam
This is not an unexpected behavior. MoveL_Test requires passing the joints from the start point (first parameter) and the destination pose (second parameter).
I recommend you to take a look at the example attached.
This example creates a cube of targets that are followed by the robot in a program. It tries to use linear movements as much as possible (using MoveL_Test first to validate the linear movement this is possible). Although may want to follow all the points with linear movements, you may hit a singularity, collision or axis limit. Therefore, you may have to change the robot configuration when this happens by using a joint movement (MoveJ) instead of a linear movement (MoveL).
.py   MoveL_Test_Make_Cube_Program.py (Size: 6.21 KB / Downloads: 1,352)
.rdk   MoveL_Test-Example.rdk (Size: 1.08 MB / Downloads: 1,163)
Hi Albert, thanks for your reply. I didn't quite understand it though. I'll try to make myself more clear.
I've attached a short code snippet of what I'm doing - going through all inverse kinematics solutions of the original pos, to verify if I have a linear path from origin to the pos destination.
I'm using MoveL_Test since in your documentation, all it does is validate if there is a linear path between current joint configuration and end pos of the gripper.
What happens is that after using MoveL_Test - the arm itself moves (hence the function does more than just validate if the motion is possible).
If this is indeed an expected behavior, I would really appreciate if you could tell me how I can verify in advance, using your API, if I can move the arm linearly from one gripper position to the other, while going through all inverse kinematics potential solutions. (since sometimes If I use your MoveL, and the joint config hits a singularity, I could have used another joint config for the same pos, without hitting this singularity)
Thanks in advance!
inverse_k_sols = self._solveIK(self.arm)   #returns all Inverse Kinematics solutions
for i in range(0,len(inverse_k_sols)):
   new_robot_joints = inverse_k_sols[:, i]
   new_linear_move_res = self.arm.MoveL_Test(new_robot_joints, target.Pose())  #FIXME: after this command, if the result is 0, the arm position is moved!
   if (new_linear_move_res != -1) and (new_linear_move_res != -2):
       self.arm.setJoints(new_robot_joints)
       self.arm.MoveL(target)
Another issue is that the return value of MoveL_Test is sometimes 0 and sometimes 1 (in addition to -1 and -2).
Could you please state the difference if there is one?
Thanks a lot for the replies,
Yotam
(02-07-2019, 08:41 AM)Yotamish Wrote: Hi Albert, thanks for your reply. I didn't quite understand it though. I'll try to make myself more clear.
Thanks in advance!
Yotam
Hi Albert and Yotamish,
I have been experiencing the same issues (the arm itself moves) when trying to use MoveJ_Test and MoveL_test for validation. Have you found a solution or a workaround?
Thanks a lot,
Rotem
