Python IO Communication for more Programs
Hello everyone;
I have question for Python in RoboDK. For Ex: I have 2 program , first python script program other one normal robodk program modul.
Program 1 : setD0(0,1)    // Python Program Line
Program 2 : Wait IO_0=1 // Normal RoboDK Simulation Prog
its possible? And any watchlist in RoboDK.
One more question about pause , I need wait time for just robot not program .
robot.Pause(time_ms=1000000) doesnt work. (Robot defined)
When you use digital outputs/inputs in RoboDK simulation you'll notice some station parameters that are automatically generated (such as IO_5=1 if you use DO[5]=1).
You can use waitDI as shown in the following link:
https://robodk.com/doc/en/PythonAPI/robo...tem.waitDI
The robot pause is not simulated but it is executed when you run the robot program on the robot or generate code for your robot.
Can you check my program ?
I can simulate Prog3 via Prog2, but I can't simulate via Prog1
.rdk   ExampleIO.rdk (Size: 966 bytes / Downloads: 916)
Is there anyone who knows to way ?
I'm not sure I understand what you are trying to do.
Prog2 sets digital output 5 to 1 and 0 immediately. I would recommend you to add a small pause if your goal is to create a pulse.
Its not important thing Albert , I wrote always same question. Dont focus Set IO_5=1 or 0 .
Wait IO_5=1 in Prog 3 ? Correct ?
When I run Prog2 SetIO5=1 , Prog3 running and flowing... Thats Ok ? Because Wait IO5=1 True ?
But..... When I run Prog1 which is the Python Program ( İncluding SetIO5=1 again same like Prog2 ) Prog3 not flowing wait Wait IO5=1 line ..
Its not clear ?
