Question regarding RoboDK API and UR10
Hello!
I'm currently working on a project using RoboDK API & RoboDK (sim) with a UR10 in it.
I'm coding using C++ and my company's libraries. Everything works just fine when it come to connecting to the sim and moving the robot using the API exclusively.
Now, our plan is to purchase a real UR10 robot and run our program on it. Will it work the same way?
will I be able to use RoboDK API the same way I'm using it to run commands on the simulator & the real robot (changing IP & ports)?
Example:
ROBOT->MoveJ(Mat* mat) ====> Moves the robot in the simulator with no problems. Will it move the real robot as well without any changes other than IP & port?
If not, how will would suggest I approach this?
Thank you!
Edan
Hi Edan,
Yes, you can move the real UR robot directly from your C++ code like you move the simulated robot.
You can trigger the connection using Connect (optionally passing the IP):
https://robodk.com/doc/en/PythonAPI/robo...em.Connect
(11-06-2019, 11:37 AM)Albert Wrote: Hi Edan,
Thank you Albert!
I have another question regarding Read/Write IOs.
I know you can set Digital Output (1/0) on the robot with SetDO(). Is there a way to READ these values using C++?
Further more, I've probably missed the functions in the API, but what are the ways to Read&Write variables (ints, strings, etc...) using C++?
Edan
Hi Edan,
Yes, you can read digital inputs through the API by using getDI:
https://robodk.com/doc/en/PythonAPI/robo...Item.getDI
(11-11-2019, 06:57 PM)Albert Wrote: Hi Edan,
I can't seem to find this function in the C++ API or in the source/header file.
Do I need to add the function myself?
Thank you,
Edan.
Hi Edan,
The option to read digital inputs has been recently added so you may have to take our latest RoboDK API files (robodk_api.h and robodk_api.cpp) from the RoboDK API repository on GitHub:
https://github.com/RoboDK/RoboDK-API/blo...pi.h#L2238
