06-30-2026, 10:23 AM
I have some questions about the TCP calibration by XYZ plane method. I usually use 4 point method with teaching spikes and the controller's builtin calibration method. In order to improve the calibration I am now using a probe and RoboDK however the I am surprised to see the result is worse.
Should the same point on the plane be touched or should the different postions be as far apart as possible?
When using an ABB robot with AbsAcc should poses or joints be used to feed the calibration data to RoboDK?
Thank you in advance.
Best
Best
