06-12-2025, 11:13 AM
Hi everyone,
We have acquired a Motoman Robot together with a YRC1000 controller at our Institute. We are looking towards using the MotomanHSE driver function in order to help us 3D-print with said robot.
We have now stumbled upon some problems we would like your help with:
1. After we have succesfully connected the robot and were able to moveit, as soon as we tried to run the 3D-printing project it tells us: "Set tool not supported". The protocol says: "Setting the tool is not supported with Yaskawa/Motoman robots. You should manually set the tool first or set it using a JBI program." We have already deleted the Set Tool event out of the program events of the 3D printing options. We have also tried changing the tool name. Coud you please help us solve this?
2. Is there a possibility to control/sychronize the extruder using RoboDK without going the postprocessor + .job file route? Do you have any experience with this, what hardware and protocolls do you suggest using and is it possible to also use the MotomanHSE driver for this?
Thanks for your help,
Sara
Sara
