Raycasting in Robodk
I am creating a simulation where I need to trigger a stop function on my running simulation if there is movement in a certain area. I was thinking of ray casting for this, but I haven't been able to find any info on this. I also tried using the laser to no avail.
Is this not a feature in RoboDK? If so, is there any way I can possibly achieve this?
You should be able to call Stop on a robot or a program to stop them:
https://robodk.com/doc/en/PythonAPI/robo....Item.Stop
Hi Mjavala,
I think what you are trying to do is simulate a light/laser curtain.
What Albert gave you is a way to stop the program once the laser curtain is triggered.
To create the laser curtain itself, I think I would use this API call: https://robodk.com/doc/en/PythonAPI/robo...ision_Line
It will let you define a line (or many lines) and trigger a collision as soon a something cross that invisible line.
Let me know if it helps.
