09-19-2023, 03:34 PM
I noticed you have some important G1 movements commented. For example, these movements around line 37 should not be commented:
I also noticed that some other important Gcode lines are commented such as this one:
This line sets the Z level for the whole layer and it should not be commented, at least setting the Z value should not be commented.
Also, I see that the Z level is taken from line 13 with both projects. This line sets the Z value to 400 mm and it should be commented. It has no effect on robots:
; intro line
;G1 X170 F1000
;G1 Z0.2 F720
;G1 X110 E8 F900
;G1 X40 E10 F700
G92 E0Code:
G1 Z1.5 F3600Also, I see that the Z level is taken from line 13 with both projects. This line sets the Z value to 400 mm and it should be commented. It has no effect on robots:
M201 X2500 Y2500 Z400 E5000 ; sets maximum accelerations, mm/sec^2
