Rendering issues
I'm currently testing out a small robot arm from China (mirobot), and needed to import the .stl files into RoboDK
- stl files: https://github.com/wlkata/Mirobot-STL
- Manual (parameter): https://lin-nice.github.io/mirobot_gitbo...lkata.html
The parts are not rendered (No problem with .robot files from library). The workspace however is displayed.
Any help would be very appreciated.
Thank you and have a nice day.
Hi Gipfeli,
Can you provide the .rdk file you used.
(01-06-2021, 02:17 PM)Jeremy Wrote: Hi Gipfeli,
Sure, here you go. https://drive.google.com/file/d/18yYSX2c...sp=sharing
Thank you very much.
Hi Gipfeli,
I'm not so sure what's going on, but your mesh (.stl) smees a bit broken.
I tried opening them with a CAD software (Fusion 360) and the result was quite strange.
Could you save the parts as either .step or .iges instead of .stl?
I would recommend those formats over .stl.
