I would like RoboDK to include a feature that can overrule/ignore all feed/speed values imported from CAM (e.g. Fusion 360), so I can define global values for MovL, MovJ, and other speed parameters – regardless of what the CAM has set. I am using Yaskawa DX200 MH50.
Current issue
Motivation
This would make it much faster to tune speeds on the shop floor, ensure consistent .JBI files, and reduce errors when CAM projects contain mixed feed values.
Thanks for considering this request!
Hardware: Yaskawa DX200 MH50
Workflow: Fusion 360 → RoboDK → Post to .JBI
Best Regards.
Stig
Current issue
- CAM injects speeds per operation/toolpath.
- The RoboDK “Program Event” (where you can set speed) does not always affect the final .JBI after post-processing.
- This results in inconsistent speeds and extra work when testing or scaling feeds globally.
- A global menu/setting in RoboDK that:
- Forces a global linear speed for MovL (mm/s).
- Forces a global joint speed for MovJ (% or deg/s, depending on post).
- (Optional) Forces global acceleration/blend if relevant.
- Provides control of other speed values (e.g. spindle speed, tool speed, or other execution speeds supported by the post).
- Applies to the entire program (and subprograms), regardless of CAM defaults.
- Must work after import and before post-processing, so the final .JBI reflects the global values.
Motivation
Best Regards.
Stig
