Request to Add EFORT GR6150-2900 Robot Model and Post Processor
I would like to request support for the EFORT GR6150-2900 industrial robot.
The robot model is essential for my current project, and I would greatly appreciate it if an official GR6150-2900 model could be added to the RoboDK robot library.
If possible, I would also like to request a post processor for the EFORT controller, so that programs generated in RoboDK can be exported for use on the real robot. The post processor is not mandatory at this stage, but it would be very helpful if it could also be provided.
Reference file: https://www.efort.com.cn/index.php/servi...e/200.html
Thank you very much for your help and support.
Best regards
Here is the robot, let me know if something is incorrect with it.
.robot   Efort-GR6150-2900.robot (Size: 373.2 KB / Downloads: 38)
Hello Olivier,
Thank you for providing the EFORT GR6150-2900 robot model so promptly. I have reviewed it and it appears to be correct for our application—no issues to report on the model itself.
At this point, I would like to request that RoboDK consider adding a post-processor for EFORT robots to the official library. EFORT’s robot controllers are based on the Robox RP-2 platform (from Robox S.p.A., Italy), which is the controller used on our GR6150-2900 and other EFORT robots.
From Robox’s technical documentation, the RP-2 controller supports robot programming through several languages, most relevantly RPL (Robot Programming Language) and R3 (structured text), developed within the RDE (Robox Development Environment). A RoboDK post-processor would therefore need to generate program files that are compatible with the RPL/R3 environment used on these controllers, so that programs simulated in RoboDK can be exported and executed on the real EFORT robot without manual rewriting.
Thank you again for the model and for your continued support. Please let me know if there is any additional information I can supply to help move this request forward.
