Request to Add ROKAE SR5-C
Our team recently purchased a ROKAE SR5-C and would like to simulate it with RoboDK.
Would it be possible to add the robot to the library?
.pdf   ROKAE_xMate SR-C.pdf (Size: 1.85 MB / Downloads: 694)
.zip   xMate SR5-C_Models.zip (Size: 3.58 MB / Downloads: 530)
@Olivier will be adding this robot to the library soon and we'll let you know.
Thank you for sharing the 3D models of this Rokae robot.
I've joined the robot but I am not sure about the joint sense, can you confirm before I push it in the library or share a picture of the robot with all joints at 30 degree?
.robot   Rokae-SR4-C.robot (Size: 3.31 MB / Downloads: 589)
Hello, thank you for preparing the ROKAE robot.
My colleague took the photo of the robot with 30 degrees.
Could you place the robot on your library as the SR5-C, not SR4?
It is because SR4 is the same spec with SR5, but the user prefers higher payload.
