  • 1 Vote(s) - 4 Average
Request to add FANUC CRX-30iA Workspace
Hello RoboDK team,
Some of our clients request to add FANUC CRX-30iA.
I attached the data on this post.
The specifications are similar to the CRX-25iA, with the change being a shorter maximum reach distance of 1756 mm.
CRX-30iA | CRX Collaborative Robot
.zip   3D_CRX-30iA_v01.zip (Size: 4.48 MB / Downloads: 607)
A preliminary version of the Fanuc CRX-30iA robot is attached.
Please let us know if any changes are needed.
.robot   Fanuc-CRX-30iA.robot (Size: 345.8 KB / Downloads: 542)
Dear Sergei,
Thank you for creating the robot.
It is fine for the general work range of CRX-30iA, but is it possible to create another version of 1756mm reach in operating in 30Kg payload mode separately?
Best Regards,
Hiroe
 SergCRX-30iACRX-30
eiSer
.pdf   CRX-30iA-data-sheet.pdf (Size: 302.08 KB / Downloads: 414)
Dear Hiroe!
Unfortunately, implementing such a workspace does not have a straightforward solution.
Please contact us by e-mail if you would like to discuss this specific request.
(12-24-2024, 11:32 AM)Sergei Wrote: Dear Hiroe!
Dear Sergei,
OK, we noted.
Thank you for your support as always.
Best Regards,
Hiroe
Dear Hiroe,
We could implement a virtual wall using a plugin. Something similar to the lock TCP Add-in:
https://robodk.com/addin/com.robodk.plug...ginlocktcp
This would require some development. Contact us by email if this is a requirement and we can discuss further. This could be a joint development.
Thanks,
