05-04-2020, 08:53 PM
I have a machining project with particularly tight working conditions. No matter the machining settings, I'm getting what looks like 90 degrees of Z rotation, even when the "Allow a tool Z rotation of..." is set to 0 or 5 degrees.
I'm currently using Minimum tool orientation algorithm, because Tool Orientation follows path produces very jerky motion
I need to be able to restrict z roll. Ideally all the way down to none at all.
I cannot post the .rdk at this time without removing a good amount of customer info, but a settings screenshot is attached
