Rhino model scale issue
Hi All,
When I load a geometry from rhino to RoboDK, the loaded shape become out of scale. Is there a way to calibrate the units in Rhino and RoboDK? Also, I was wondering if there is an end-effector for concrete extrusion can be installed on RoboDK.
Thank you,
What units are you using? Can you provide the Rhino 3dm model?
As a workaround, you can double click the part in RoboDK, select more options, then, scale.
