RoboDK Crashes when Dragging Instructions within Program to Change Order of Execution
RoboDK is crashing constantly whenever I click and drag instructions within programs to change their order.
I insert an instruction to the program and then decide I need to move it a few steps before or after its current position, so I click and drag the instruction and before I can drop the instruction (or while dropping it) in its new position, RoboDK will crash on me.
I've tried right-clicking to drag as well as left-clicking and get the same results.
This has happened over a dozen times in the last 2 hours.
I'm running RoboDK v5.0.1 with a Professional license on a Windows 10 Pro system.
I installed the latest version (v5.0.2) to see if that would fix this issue, but it crashed on the first attempt at moving an instruction within the same program.
Windows Event Viewer shows the following:
Faulting application name: RoboDK.exe, version: 5.0.2.18542, time stamp: 0x5f410399
Faulting module name: Qt5Widgets.dll, version: 5.11.2.0, time stamp: 0x5b99ead3
Exception code: 0xc0000005
Fault offset: 0x00000000003f9d90
Faulting process id: 0x5624
Thank you for letting us know, this issue was fixed last year. Make sure to update RoboDK to the latest version.
