RoboDK closing right after opening
RoboDk closes right after being opened. My current version is 5.8 but I had the same problem with 5.5.3 since reinstalling my laptop's drivers. Right now I have the most recent Nvidia Geforce GTX drivers available.
I tried rebooting RoboDK only and later my laptop, to no avail.
Also tried starting RoboDK via RoboDK.Debug.bat, this gave the same result. The following are the resulting errors:
15:10:23.622 (+0 ms): RoboDK v5.8.0 debug file RoboDK.debug.txt, started on 27-12-2024-15:10:23.622
15:10:23.622 (+0 ms): Debug: OS:  WIN64
15:10:23.622 (+0 ms): Debug: Date build:  Sep 23 2024
15:10:23.622 (+0 ms): Debug: Main process ID:  18044
15:10:23.622 (+0 ms): Debug: Thread ID:  0x4e70
15:10:23.669 (+47 ms): Debug: Processing event...
15:10:23.670 (+1 ms): Debug: Starting RobotTools...
15:10:23.674 (+4 ms): Debug: Loading settings...
15:10:23.674 (+0 ms): Debug: Setting up default settings...
15:10:23.674 (+0 ms): Debug: Default settings set
15:10:23.674 (+0 ms): Debug: Reading saved settings...
15:10:23.676 (+2 ms): Debug: Settings loaded
15:10:23.701 (+25 ms): Debug: Lang file not found:  "C:/RoboDK/Lang/qt_en.qm"
15:10:23.701 (+0 ms): Debug: Statusbar:  "Language set to English"
15:10:23.703 (+2 ms): Debug: Updating recent files menu...
15:10:23.706 (+3 ms): Debug: Created language menu
15:10:23.723 (+17 ms): Debug: Setting slider style...
15:10:23.723 (+0 ms): Debug: Done
15:10:23.726 (+3 ms): Debug: Image_Mix Warning 2nd image is larger  ":/img/python.svg"  ":/img/tagadd.png"
15:10:23.729 (+3 ms): Debug: Trying to set up SpaceMouse...
15:10:23.733 (+4 ms): Debug: SpaceMouse setup done
15:10:23.742 (+9 ms): Debug: Setting up graphics...
15:10:23.752 (+10 ms): Debug: Setting up main window...
15:10:23.764 (+12 ms): Debug: Starting main window...
15:10:23.786 (+22 ms): Debug: LC start...
15:10:23.788 (+2 ms): Debug: LC message:  LC device not found
15:10:23.788 (+0 ms): Debug: Dongle not found or cannot read
15:10:23.788 (+0 ms): Debug: LC start...
15:10:23.788 (+0 ms): Debug: LC message:  LC device not found
15:10:23.791 (+3 ms): Debug: Loading plugin:  "C:/RoboDK/bin/plugins/CollisionFreePlanner.dll"
15:10:23.792 (+1 ms): Debug: Loading plugin file:  "C:/RoboDK/bin/plugins/CollisionFreePlanner.dll"
15:10:23.792 (+0 ms): Debug: Loading plugin  "CollisionFreePlanner"
15:10:23.792 (+0 ms): Debug: Using settings:  ""
15:10:23.792 (+0 ms): Debug: Setting up the status bar
15:10:23.794 (+2 ms): Debug: Inserting menu at the end of the utilities menu
15:10:23.794 (+0 ms): Debug: Setting up the menu bar
15:10:23.795 (+1 ms): Debug: List of LOADED plugins:
15:10:23.795 (+0 ms): Debug:      "CollisionFreePlanner"
15:10:23.795 (+0 ms): Debug: Done list of plugins
15:10:23.795 (+0 ms): Debug: Statusbar:  "Loaded 1 plugins"
15:10:23.795 (+0 ms): Debug: Reading preferred layout settings...
15:10:23.795 (+0 ms): Debug: Closing splash window
15:10:23.839 (+44 ms): Warning: Vertex shader for simpleShaderProg (MainVertexShader & PositionOnlyVertexShader) failed to compile
15:10:23.839 (+0 ms): Warning: Fragment shader for simpleShaderProg (MainFragmentShader & ShockingPinkSrcFragmentShader) failed to compile
15:10:23.842 (+3 ms): Warning: QGLShaderProgram: shader programs are not supported
15:10:23.842 (+0 ms): Critical: Errors linking simple shader:
15:10:23.842 (+0 ms): Warning: Vertex shader for blitShaderProg (MainWithTexCoordsVertexShader & UntransformedPositionVertexShader) failed to compile
15:10:23.842 (+0 ms): Warning: Fragment shader for blitShaderProg (MainFragmentShader & ImageSrcFragmentShader) failed to compile
15:10:23.842 (+0 ms): Warning: QGLShaderProgram: shader programs are not supported
15:10:23.842 (+0 ms): Critical: Errors linking blit shader:
Please help, Thanks
This issue is related to incorrect graphics card drivers. Are you using RoboDK on a new computer? Did RoboDK ever work on this PC?
You can try running RoboDK by double clicking on this file:
C:/RoboDK/RoboDK-Safe-Start-VM.bat
(12-27-2024, 03:08 PM)Albert Wrote: This issue is related to incorrect graphics card drivers. Are you using RoboDK on a new computer? Did RoboDK ever work on this PC?
RoboDK worked before on this PC, however I had to reinstall my drivers with Guru DDU. After doing this, RoboDK wouldn't start anymore.
I tried booting RoboDK with Safe Start, but it makes no difference.
I recommend you to revert back to original settings by following these steps:
  1. Run the script C:/RoboDK/RoboDK-Set-Defaults.bat
  2. Start RoboDK
Let me know if it works any better.
Hi Albert, many thanks! It is working again.
Great, thanks for letting us know that reverting the settings back to default made it work.
3 Guest(s)
