RoboDK for laser/watrejet cutting
Hello gents,
we are trying to run waterjet cutting tool fixed on staubli tx90 arm. The method is exactly the same as you shown for laser cutting and part programming with fusion360. VAL3 post processor works perfectly!!!...even for learners!...except I did not find control on "power on"/"power off"...maybe could you guide how to access it?...or should I create two subprograms for power on and power off?
many thanks in advance
Giedrius
How is your waterjet turned off/on? Is it through a digital Output?
Yes, we would recommend creating a subprogram to turn on/off so you can call it at anytime during your program and if anything changes on how you turn it on/off you just have to make the modifications in one place.
(01-12-2022, 05:37 PM)Alex Wrote: How is your waterjet turned off/on? Is it through a digital Output?
Yes, it is through DO.
