04-01-2019, 05:44 PM
RoboDK not working properly |
04-02-2019, 08:21 PM
Hi avpai1992,
That would be pretty strange, but considering that it's a piece of software I cannot say it's impossible... I'll send you a private message with my e-mail address. Contact me there and I'll send you a new license. Have a good day. Jeremy
04-12-2019, 07:47 AM
Hi.
We had the same issue with RoboDK. It worked on 1 out of 3 computers we tested with. We solved the issue by copying the RoboDK folder from the working pc to the pc's that it did not work on. It looks like it is a version issue. The working version is 3.5.5 64bit. The non working version is 3.6.2 64bit.
You can download this older version at the following link:
https://robodk.com/download
01-26-2024, 09:54 PM
Hi guys,
I am trying to use the same example "Move robot using a keyboard" with UR, the real robot is not working properly, a jerk is produced! any help?
01-28-2024, 07:01 PM
You can use the rounding instruction to make the movement smoother and less jerky (called blending with UR).
However, this may have little effect when using the driver. |
| 2 Guest(s) |
Powered by MyBB
