12-25-2025, 02:11 AM
I'm hoping you can help me understand this issue.
My team is using FANUC robots. We have checked what tolerances cause singularities on our controller, and see them at +/- 3.5 degrees. When we set "Tolerance to avoid Wrist Singularity" to 4 degrees in RDK's Tools -> Options -> Motion, the simulation passes without flagging a singularity, but then the controller flags singularities because some robot motions do get within +/- 3.5 degrees.
Is there a discrepancy between FANUC's wrist singularity tolerance and RoboDK's Wrist singularity tolerance? I would like to capture all possible singularities within the RoboDK simulation before executing on-line with the robots.
Thank you.
Thank you.
