12-10-2024, 06:23 PM
I have been trying to set up a station using a 6-axis Fanuc robot synchronized with a 2-axis turntable. However, there seems to be a problem with the robot base moving to the 2-axis turn table when synchronizing. I would like to keep the robot base on the default Fanuc 6-axis robot base frame. To demonstrate the problem, here is a picture of the set up when the 6-axis robot is not yet synchronized to the 2-axis turn table. I have set a reference frame positioned at (2000.000, 0.000, 1040.000, 0.000, 0.000, 0.000).
Then after synchronizing the robot to the 2-axis turn table, the robot base automatically moves to the turn table base. You can see in the following picture how the reference frame automatically changes to (2000.000, -1000.000, 970.500, 0.000, 0.000, 0.000). The actual location of the reference frame is in the same place, it is only now referencing a different robot base location.
The issue is then further complicated because the tool frame (6-axis robot flange) is now tied to the 2-axis turntable. So any movement of the turn table will also move the tool frame with respect to the reference frame. When generating a robot program, this causes the coordinates to move with any turn table movements.
Is there a way to modify the robot base location so that it can be placed back on the 6-axis robot arm and also not be tied to any axis?
