Robot Meca500 in simulation not moving like the real robot
I connected RoboDK V5.2.4 to Meca500 R3 v8.1.9, when running a simulation only on RoboDK, everything is good, when running the same program on robot (right click Run on robot), the real robot is moving good but the robot in the simulation is doing weird moves, and some times, I get message errors like singularity or no path possible because the robot in the simulation is not able to reach the position,
Do you have any suggestion about this issue ?
Best regards
Can you provide some screenshots or recordings of the issue?
(07-16-2021, 12:22 AM)Jeremy Wrote: Can you provide some screenshots or recordings of the issue?
Hi, you can find attached a screen recording of the issue
Do you have an idea what could be the issue?
Best regards
.mp4   RoboDK_Connect_To_Robot_IssueEmail.mp4 (Size: 6.37 MB / Downloads: 835)
This issue should have been fixed a few months ago. I recommend you to update RoboDK to the latest version:
https://robodk.com/download
(07-19-2021, 07:47 PM)Albert Wrote: This issue should have been fixed a few months ago. I recommend you to update RoboDK to the latest version:
Thank you very much Albert, this fixed my issue, every thing is running correctly
