Threads: 3
I'm using Mecademic Meca500.
When I rotate the dial to change the robot orientation, I can see the robot on my screen moving but the real robot is not moving unless I click Move Joint.
It was moving before.
What went wrong ?
227
The real robot doesn't usually move if you move the simulation. Even if you are connected to the robot using the driver.
Were you using an Add-in? For example, Game controller Add-in or the robot pilot plugin allow you to move the simulation and the real robot at the same time.
Threads: 3
I'm not using Add-in. I am using the jog and the dial on the right screen.
It was working before.
Also on some of RoboDK videos , the robot move when moving the dial.
227
Are you referring to the real robot? The real robot does not move by default when moving the dial in the robot panel.
Do you know if you ran a custom script or an existing example? Can you share your RDK project file?
