Run C++ Code in RoboDk API for C++
I am currently working with a Kuka KR3 R540, with the KR CR 4 compact. I got it set up so far as to send PTP Movements from my Laptop to the Kuka, so there is a working connection. To integrate the Kuka into a existing system, we need it running on C++. But I am not able to get it set up for running C++ code.
I followed the instruction closely, but maybe I am missing out something.
So how do I insert C++ code into the RoboDK station ? Or how to send C++ code via RoboDK to the Kuka?
Thanks in advance.
By the way, thanks for the awesome documentation !!
Edit: I also failed to find the "RoboDK-API-Cpp-Sample.pro" as stated in the RoboDK API for C++ Dokumentation ...
I recommend you to take a look at the C++ section of the RoboDK API GitHub repository:
https://github.com/RoboDK/RoboDK-API/tre...er/C%2B%2B
You'll find an example in C++. This example requires using Qt.
You can also use the RoboDK API .Net version (NuGet Package) and integrate it in Microsoft Visual Studio for C++ without Qt dependencies:
https://www.nuget.org/packages/RoboDkApi/
Hi, thanks for your reply. I already read the documentation on github, i guess I already read anything in the internet about c++ and RoboDK...
Well, I still can't get it running. Do you think it would be possible to make a Tutorial on youtube like for the other programming languages ?
Or just a step by step manual on how to get e.g. the hexagon example running?
And could you tell me where to finde the "RoboDK-API-Cpp-Sample.pro" ?
Have a great weekend. Many thanks !!
Okay nevermind, I found what I was searching for and got it all running over the weekend. Thanks for your help!
