12-26-2024, 01:23 PM
Hello, I have an object attached to my conveyor, but when I run the RunConveyor macro script provided by Robodk, I get an error of
"if all_objects[i].count(PICKABLE_OBJECTS_KEYWORD) > 0:
AttributeError: 'Item' object has no attribute 'count'"
Could someone help me out.
Below is the full code provided by RoboDK.
# More information about the RoboDK API here:
# https://robodk.com/doc/en/RoboDK-API.html
# Type help("robodk.robolink") or help("robodk.robomath") for more information
# Press F5 to run the script
# Note: you do not need to keep a copy of this file, your python script is saved with the station
from robodk.robolink import * # API to communicate with RoboDK
from robodk.robomath import * # basic matrix operations
RDK = Robolink()
# This script simulates a conveyor belt
CONVEYOR_NAME = 'Conveyor Belt (2m)'
PICKABLE_OBJECTS_KEYWORD = 'Bottle'
# Speed of movement in MM/S with respect to the conveyor coordinates:
MOVE_SPEED_MMS = [0, 5, 0]
REFRESH_RATE = 0.005
# Define workspace of the conveyor to pick the objects:
CONV_SZ_X_MIN = 0
CONV_SZ_X_MAX = 440
CONV_SZ_Y_MIN = 0
CONV_SZ_Y_MAX = 2000
CONV_SZ_Z_MIN = -200
CONV_SZ_Z_MAX = +500
# Move objects that reached the end of the conveyor and were not picked:
FALLEN_OBJECTS = [0, 0, -500]
# Get the conveyor item and reference for work space:
conv = RDK.Item(CONVEYOR_NAME)
conv_reference = conv.Parent()
poseconv = conv_reference.PoseAbs()
# One second in real life means 1 second of simulation. The simulation speed is taken from the station
SIMULATION_SPEED = 1
def is_inside_conveyor(pose):
"""Checks if a pose is inside the conveyor workspace"""
pos = pose.Pos()
if pos[0] > CONV_SZ_X_MIN and pos[0] < CONV_SZ_X_MAX and pos[1] > CONV_SZ_Y_MIN and pos[1] < CONV_SZ_Y_MAX and pos[2] > CONV_SZ_Z_MIN and pos[2] < CONV_SZ_Z_MAX:
return True
return False
def conveyor_move_object(pose, delta_time):
"""Moves the object pose through the conveyor depending on the time and speed"""
delta_mm = mult3(MOVE_SPEED_MMS, delta_time)
newpose = transl(delta_mm) * pose
return newpose
# Get all objects (string list)
all_objects = RDK.ItemList(ITEM_TYPE_OBJECT)
# Convert object list into item pointers (faster)
# Also filter the list to take into account pickable objects only
objects = []
objects_name = []
objects_active = []
for i in range(len(all_objects)):
objects.append(RDK.Item(all_objects[i]))
objects_name.append(all_objects[i])
objects_active.append(False)
# The number of objects that can go in the conveyor
nobjects = len(objects)
print(nobjects)
# Infinite loop to simulate the conveyor behavior
current_time = 0
tic()
time_last = toc()
while True:
# First: Look for objects that are not in the conveyor but are in the conveyor workspace
for i in range(nobjects):
obj_i = objects[i]
# Skip if the object is already in the conveyor
if objects_active[i]:
continue
# Check if the object has already been taken by a tool. If so, do not take it in the conveyor
if obj_i.Parent().Type() == ITEM_TYPE_TOOL:
continue
# Check if the object is within the conveyor work area
posei = obj_i.PoseAbs()
poseirel = invH(poseconv) * posei
if is_inside_conveyor(poseirel):
# take the object
obj_i.setParentStatic(conv)
print('Adding object %s to the conveyor' % objects_name[i])
objects_active[i] = True
# Second step: Update the position of every object in the conveyor
SIMULATION_SPEED = RDK.SimulationSpeed()
time_current = toc()
time_delta = time_current - time_last
time_last = time_current
current_time = current_time + time_delta * SIMULATION_SPEED
# Make a list of objects with their matching positions to update
obj_items = []
obj_poses_abs = []
obj_i = objects[i]
# Check if the object has been picked from the conveyor
if objects_active[i] and obj_i.Parent() != conv:
objects_active[i] = False
print('Object %s was picked from the conveyor' % objects_name[i])
continue
# Skip update for objects that are not in the conveyor
if not objects_active[i]:
continue
# Update the position of the object
posei = invH(poseconv) * obj_i.PoseAbs()
newposei = conveyor_move_object(posei, time_delta * SIMULATION_SPEED)
if not is_inside_conveyor(newposei):
print('Warning!! Object %s fell from the conveyor at %.1f seconds after simulation started' % (objects_name[i], current_time))
raise Exception('Object %s was not picked from the conveyor!' % objects_name[i])
newposei = transl(FALLEN_OBJECTS) * newposei
#obj_i.setPose(newposei) # this will provoke a refresh (can be slow)
obj_items.append(obj_i)
obj_poses_abs.append(poseconv * newposei)
# Update the object positions
RDK.setPosesAbs(obj_items, obj_poses_abs)
# Take a break...
pause(REFRESH_RATE)
