Saving and Importing a Custom Mechanism
Is there a way to save a custom mechanism so that it can be imported into a station similar to the mechanisms in the on-line library ?
When I save my custom mechanism it is saved as a station that cannot be inserted into a new station.
Hi John,
"Right-Click" the mechanism in the station tree -> "Save as"
That will create a .robot file that you can load in any station the same way you can do with the external axis from the online library.
(05-25-2021, 03:16 PM)Jeremy Wrote: Hi John,
Thanks Jeremy,
I did manage to use the CtrL C / Ctrl V to paste a mechanism into a different station.  The robot file sounds better
so I can re-use
