Schneider Cobot Lexium Post Processor
Dear Albert Sir,
We are trying to generate a program for curve follow project in RoboDK for "Schneider lexium 12 kg cobot"
When I am trying to generate a program its showing the error. how i can generate the program for this cobot by selecting right post processor?
We recently updated RoboDK to include support for Schneider robots.
Did you try with the latest version of RoboDK? What error messages do you see?
This is the error:
Failed to generate program "Path2" using the Post Processor Schneider
Post processor path: C:/RoboDK/Posts/Schneider.py
File "C:\RoboDK\Posts\Schneider.py", line 35, in
from libspp.Schneider import RobotPost as MainPost
File "C:\RoboDK\Python-Embedded\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
return original_import(name, *args, **kwargs)
File "Schneider.py", line 115, in init Schneider
AttributeError: module 'JAKA' has no attribute 'JAKAZuProg'
During handling of the above exception, another exception occurred:
File "C:\Users\Admin\AppData\Local\Temp\PostPath2.py", line 15, in
from Schneider import *
File "C:\RoboDK\Posts\Schneider.py", line 45, in
raise Exception(msg)
Exception: Invalid Python version or post processor not found. Make sure to download the latest version of RoboDK.
Select Tools-Options-Python and select a supported Python version
This script was executed using Python 3.10.10
Information about the error:
AttributeError("module 'JAKA' has no attribute 'JAKAZuProg'")
Process output:
Using Python version: sys.version_info(major=3, minor=10, micro=10, releaselevel='final', serial=0)
RoboDK Post Processor: C:\RoboDK\Posts\Schneider.py
RoboDK Post Processor: C:\RoboDK\Posts\JAKA.py
Python Post Processor process exit code: 0
Yes we tried with the latest version of RoboDK and mentioned error we are getting at the time of program generation
We noticed there is a bug with the Schneider post processor.
Could you use the post processor attached instead? You can simply unzip the contents in C:/RoboDK/Posts/
Make sure you are using the latest version of RoboDK. This should be fixed with the next update.
.zip   Schneider.zip (Size: 3.36 KB / Downloads: 327)
(11-25-2025, 11:20 AM)Albert Wrote: We noticed there is a bug with the Schneider post processor.
I followed the steps but it is generating the program with .jks format which is i am unable to add into the software. Please update on the same.
The post processor should have also generated a .zip file that you should be able to import on your controller.
Thank you for assistance. generated program working now.
Great, thank you for your feedback.
