Setting defaults in PROGRAM EVENTS
Hi guys
We have a Kuka KR210 KRC-2 robot which we control with RoboDK to saw Quartz and Granite kitchen countertops. We import dxf drawing files of the pieces which we cut from big slabs.
When we import we create the mills with DXF2gcode.
Currently we add program events, eg "Spindle on" code at path start and and "Spindle off" code at path for EVERY dxf drawing which we import.
We would like to add such events as DEFAULT program events to the mills at path start and path end which should be already there every time we import a dxf file. It is wasting a lot of time to have to do it every time we import a dxf file.
Please advise how to do this.
Kind regards
Curt
Go to "Tools"->"Options"->"CAM"->"Program Events".
You can set default values for the Robot Machining Projects there, including Program Events, Orientation, Algorithm, etc.
(12-21-2021, 02:39 PM)Jeremy Wrote: Go to "Tools"->"Options"->"CAM"->"Program Events".
Thanks Jeremy, Can't believe I missed it! the biggest button on the CAM screen is Program Events
