Side (NxT) approach not working in curve follow project
I am trying to use a combination of approaches in a curve follow project and when I try to use the Side approach, the robot has a strange behaviour, moving to a place it should not and then coming back to the normal path.
Is it a known issue ?
Thanks,
Camille
Can you provide a .rdk example file so that I can try reproducing the issue.
Here is a station with the bug :
.rdk   Bug.rdk (Size: 609.33 KB / Downloads: 994)
Thanks,
Camille
Hi Camille,
Ok good, this definitely looks like a bug.
I transferred the info to our dev team.
Hi Jeremy,
Just an update to inform you the bug is now also on the [X,Y,Z] Abs. and [X,Y,Z] Rel. options.
I think they were working before.
Camille
