Slic3r settings problems
Whenever I try and use the 3D printing module and I select a part for 3d printing I get an error message that says "Current 3D printing settings do not produce any result, Use appropriate 3D printing parameters for the selected part."
I have tried many different settings in slic3r and every time I get the same error message. Even when I use the supplied box for 3d printing it does not work. Any ideas where I could be going wrong.
The IRB120 3d printing demo does work though.
Running Slic3r 1.3.0 and RoboDK v4.0.0
Well I think I figured it out. I think the object that was to be printed was using a reference frame that was not correct some how. I will see if I can re create the problem and post it.
