SolidWorks RoboDK Fanuc R2000iB 210F
Привет. программирование робота в роботке. Я создаю траекторию с помощью SolidWorks. Линии все прямые, а по факту получается со смещением. подскажите, что можно, или скачать другую программу на место солидворкс и там попробовать?
WhatsApp Image 2022-03-25 at 07.20.36.jpeg    WhatsApp Image 2022-03-25 at 07.20.37 (1).jpeg    WhatsApp Image 2022-03-25 at 07.20.37.jpeg
This looks more like a robot setup problem than a software problem.
How did you set up your tool and how did you set up your frame?
[quote= 16482109508227925139722417801809.jpg    16482108640727072277019579476893.jpg    16482107888334809887553102009061.jpg
I'm sure they are the same in RDK and in the controller but are they right?
What I mean by that is, does your in the virtual environment matches with your part in the real environment.
https://youtube.com/playlist?list=PLjiA6...LBNEmBE57E
thanks. I will try.
did everything as in the video. in 2d processing is good, in 3d there are displacements.
I have an r 30ia controller. fanuc rj3 postprocessor works and r30ia postprocessor doesn't load into controller ?
What error message do you see when you load the file?
Can you share the complete error log? We are unable to help you troubleshoot without more information.
