06-23-2019, 07:44 PM
Hi, i have successfully been able to move a Staubli Tx90XL with robodk, I am using it to create fast camera moves.
Now I need to sync an external axis witch will control focus gear of the camera (this axis need to be sync with robot program of robo dk)
Could any one throw some light on it,
I was thinking on a "reference frame" linked to the TCP which calculate distance between to move this external axis in sync with robodk program.
The External motor use 3v3†Level†UART¨†5v†tolerant†57¨600†Baud†8†data†bits¨†no†parity¨†1†stop†bit
As I spoke to Staubli I got this answer:
"the easiest is to insert an RS232 to UART (TTL) adapter. Like this you will be able to dialog with your tool using the RS232 interface of the CS8C.
In VAL3, you have to create an sio variable that you link to the CS8C serial interface.
You then have to write in VAL3 your own communication drivers following tools manufacturer specification.
And Then link it to RoboDK somehow."
Any one could help here with communication between RoboDK-Val3-External Axis?
(have everything ready, manufacturer communications protocols, rs232 to uart, cable, ...) need the master mind to do the programing, an I would like to pay for your time.
Please contact me over forum or Mail (newokone@gmail.com)
Regards
Regards
