Threads: 16
11-02-2025, 09:05 PM
(This post was last modified: 11-05-2025, 01:20 PM by Albert.)
I just sent the request. Thanks!
Threads: 16
11-03-2025, 07:32 PM
(This post was last modified: 11-05-2025, 01:19 PM by Albert.)
Hello Albert,
I have received the source code files, but I am not sure how I should be solving my current issue with those. Could you please provide some insights?
Thanks for your help!
222
The post processor allows you to customize the behavior when you generate a program.
For example, calling a subprogram triggers the RunCode function of the post processor.
222
If you are planning to customize your post processor I recommend you to rename it and place it in C:/RoboDK/Posts/
If you don't rename the post processor it will be overridden automatically with a new install of RoboDK.
Threads: 16
11-07-2025, 07:20 PM
(This post was last modified: 11-11-2025, 09:11 AM by Albert.)
When I generate a robot program and then proceed to "Add/Edit Post Processor," the resulting Python script is the default template and does not contain the movement information from the main .jks program. I expected this Python script to hold all the movement details after program generation.
For context, in the zip folder provided by Konstantinos, there are three python files: apijaka, JAKA_POST and JAKAZu. I have copy pasted three of them into RoboDK/posts but only using the "JAKA_POST as the post processor.
I apologize for the repeated questions, but I could find only one video on post processor, therefore I am very confused.
