Synchronising equipment with Robot simulation
I need to synchronise an equipment  (eg a multi axis machine)  imported in RoboDK with the robot.
I have a file describing machine axis positions= f(t).
I need to know the Robot Simulation time step in order to set the machine in the right position .
How can I retrieve the robot simulation time  step ?
Can I use the plugin Render event in order to update the machine positions ?
Regards,
Stéph
Hi Stéph,
You can retrieve the simulation speed and time using the SimulationSpeed and SimulationTime call:
RDK = Robolink()
simtime_speed = RDK.SimulationSpeed()
simtime  = RDK.SimulationTime()
The simulation speed is a ratio that represents how much faster the simulation is compared to the real time. More information here:
https://robodk.com/doc/en/PythonAPI/robo...ationSpeed
It is also possible to retrieve the simulation time using SimulationTime:
https://robodk.com/doc/en/PythonAPI/robo...lationTime
(this function has been added today for Python, available on GitHub)
