The behavior of setPoseTool is buggy
Hello
I asked about this in another thread, but now that I know more about it I'll report it here.
Sorry for the multiple posts
After calling Connect() without connecting to a robot, An error occurs when using setPoseTool().
I've included the code and Project below, so check it out.
Please let me know how to avoid this error
from robodk import robolink    # RoboDK API
from robodk import robomath    # Robot toolbox
from robodk import *      # RoboDK API
from robolink import *    # Robot toolbox
RDK = robolink.Robolink()
robot = RDK.Item("Yasakawa GP50")
tool = RDK.Item("FLANGE")
robot.setPoseTool(tool)
robot.Connect()
robot.Disconnect()
WARNING: Robot connection problem: Connection problems
  File "c:\Users\xxxx\AppData\Local\Temp\Prog1.py", line 23, in <module>
  File "C:\RoboDK\Python\robodk\robolink.py", line 5555, in setPoseTool
    self.link._check_status()
  File "C:\RoboDK\Python\robodk\robolink.py", line 835, in _check_status
    raise Exception(self.LAST_STATUS_MESSAGE)
Exception: Robot connection timed out: Connection problems
.rdk   demo.rdk (Size: 4.79 MB / Downloads: 380)
Connect raises a warning saying that the connection did not succeed. You can use ConnectedState to know if you are connected to the robot.
Either way, you could implement a try/catch to know when the connection fails and reconnect again. This could happen if the link between the robot controller and your computer is broken.
The latest version is used.
The problem is that if you try to Connect without being connected to a robot, the connection with RoboDK becomes unstable, and a timeout error occurs with the next API command.
We believe that the reason for this is that RoboDK continues to send a connection signal to the Robot even after the robot.Connect() return value, preventing the processing of the next API command.
And, I found the solution.
When an error occurs in Connect, reconnecting with RoboDK will prevent a timeout from occurring on the next API command.
Please let me know if there is another way to solve this error.
I wrote the solution code below.
thanks
from robodk.robolink import *
from robodk.robomath import *
rdk = Robolink()
robot = rdk.Item("Yaskawa GP50", ITEM_TYPE_ROBOT_ARM)
tool = rdk.Item("FLANGE", ITEM_TYPE_TOOL)
try:
    robot.Connect()
except:
    rdk.Connect()
finally:
    rdk.Connect()
I don't see the point of retrying to connect outside of the try/catch. I would approach this scenario in this manner:
while True:
    try:
        robot.Connect()
        ExecuteYouInstructions(robot)
        break # done: exit the main while
    except Exception as e:
        print(str(e)) # Print the error to know what is going on
        robot.Disconnect()
        robot.Disconnect() # This simulates a double click to Disconnect which provokes killing the driver process
        print("Retrying...")
Actually, after further discussion with our team, setting the tool on Motoman robots is not supported. You should set the tool manually first or using a JBI program file. Note that setting the tool with a JBI program requires support for the SETTOOL command which is not available by default.
